HTTP Read
The HTTP Read module allows you to process images from remote site across the internet instead of from your connected webcam. This module can also be used to access internet enabled webcams that may be connected on your local network.
1. Camera Type - select which type of camera you wish to connect to.
2. Url - Enter the web URL in the provided box. The url should be a HTTP Push server or to a single web image that when reloaded would provide a different image. Any url provided via the Camera Type dropdown will need to be configured for your domain. If your camera type does not appear in the Camera Type list you will need to find the appropriate url to use that when access will deliver a MJPEG image over a http protocol.
3. Enter the HTTP Method in the dropdown
4. Username/Password - Enter any Basic HTTP authentication in the username and password text boxes.
5. Headers - Enter any additional HTTP headers needed
6. Refresh Frequency - Select how frequently the image should be reloaded. In the case of HTTP Push the image will always be updated as quickly as the remote server provides the image.
1. Insert the HTTP_READ module (located under the Loading/Saving level) into the RoboRealm processing pipeline.
2. Enter the url specific to your camera. For the Axis 206 you would enter in your url looking something like
http://camera.ip.address/mjpg/video.mjpg
but note that your IP number will most likely be different. If you do not know the url of your camera image you may need to look under the hood of a HTML page that shows the streaming image. You most likely have that page installed with the software that comes with the camera. Using your browser select 'view source' and look for the url.
3. Press the "start" button and if you don't get any errors then you should then see the image start streaming.
The HTTP_READ module does NOT read HTML pages. You need to provide it with the specific url that will return a jpeg image. If will understand both moving jpeg images (mjpg) OR still jpeg images that refresh each time they are reloaded.
Note that DLink, TRENDnet and Linksys cameras have their own modules specific to those cameras to allow for more of the camera features to be accessed in RoboRealm.
HTTP Text Module
