VLC Player
The VLC Player module uses the Open Source VideoLan VLC media player to play video files within RoboRealm that can be processed by additional modules.Note that with the addition to video files you can also hook into image streams broadcasts over the Internet in RTSP format. This is similar to the Http Read component but can accept a different streaming format.
VLC *MUST* be installed in order for this module to work. Please download VLC from the VideoLan website.
1. Filename/Url - Specify the file or url to read in the "Filename/URL" textbox. The VLC player can accommodate .avi, .wmv, and .mpg files to name only a few of the supported formats.
2. Loop Playback - If you want to loop the playback (only valid for files) then check the "Loop Playback" checkbox.
3. Timeout - On playing videos being streamed over the network a delay is needed in order to allow for network speed fluctuations. If you are playing videos that are stored locally you can reduce the timeout delay which will also be noticed when the video loops. If you are playing files over the network and the timeout is too small the video may accidentally restart as a result of a timeout. Increasing the timeout tells the VLC module to wait longer until a new frame arrives over the network before resetting.
3. Playback Speed - To change the playback rate of the video select the appropriate playback speed. Numbers lower than 1 reduce the speed while numbers greater than one increase it. This reduces or increases the time delay between frames.
4. Frame Increment - If you want to skip over the video and only process every other frame set the increment to 2. This will cause every other frame to be skipped.
5. FPS - Displays the current Frames Per Second that the video is recorded in.
6. Skip - To Skip the first or last part of the video configure the "Skip First" and "Skip Last" accordingly. When the video loops the first X seconds, milliseconds, etc. will be jumped over. Similarly the video will end X seconds before the actual end of the video. Note that this is not cropping or modifying the video in any way.
7. Time - Displays the current frame time of the video. Changing this value will move the video to that time point.
8. Start - You MUST press the "Start" button to begin playing. Once pressed you can also manually stop the playback by pressing "Stop" (the "Start" button will change to "Stop" once playing starts). You can also Pause the video and use the Time or Slider controls to move the video to a point of interest.
Note that you must press Start for the playback to start streaming. Simply pressing OK will NOT begin playback. Also be aware that for Internet based streams you need to wait about 20-30 seconds after pressing the start button for playback to actually start.
Note that if RoboRealm appears to freeze the connection may be down. Wait for about 20 seconds and you will regain control after the network connection times out.
Variables
VIDEO_SECONDS - specifies in seconds where the current video frame is within the video. VIDEO_TIME - specifies the HH:MM:SS (hours:minutes:seconds) where the current video frame is within the video.
Media Reader
Read AVI
RTSP Player
HTTP Read
For more information
VideoLan Website
| New Post |
| VLC_Player Related Forum Posts | Last post | Posts | Views |
Missing libvlc.dll when trying to use VLC player
Hello There! I tried to use vlc within roborealm but i keep getting this missing libvlc.dll problem... |
10 year | 2 | 3789 |
