Display Variables
The Display Variables module will draw variables and their values into the current video stream for use in recording and display purposes. Note that the graphics are overlaid after all processing is completed to ensure that added graphics do not become part of the processed image.
When recording a filtered sequence it can be useful for end viewers to include any statistics within the image that you are trying to achieve.
1. Insert a variable by double clicking on an available variable or select a variable and click on the insert button.
2. Once a variable is in a slotted box it can be moved to alternate locations using the yellow arrow keys. Note that the double up and down arrows move the variable to the next up or below location box.
3. Dim background - Select if you would like to "dim" the background of the text area. This reduces the background of the text intensity to make it easier to read the white text.
4. Border Color - Select the color of the box that surrounds the text.
5. Font Size - Select the font size to use for displaying the variables.
6. Font Color - Select the font color to use for displaying the variables.
7. Display as Annotation - Select if you want the graphic to be draw after all processing has been completed. If this is NOT selected then the next module in the processing pipeline will see the graphic as if it were part of the image and process it accordingly.
8. When done press ok to save the current configuration. Note that any changes are immediately visible in the image preview in the main dialog.
Annotated image
Write Variables
Watch Variables
COG
 New Post
Display_Variables Related Forum PostsLast postPostsViews
Make variables easily visible
STeven, If one wants to monitor the actual values of variables at a certain position of the program...
12 year 3 3291
displaying variables
I have about 20 variables that are displayed to the user during testing. Yesterday I set them all up in order.
13 year 2 3511
Displaying variables
I have 'Display variables' set up at two points in the program. However, as I move...
13 year 3 3544
car tracking number
hi , i m new using roborealm       i have question about the car tracking at here :...
13 year 2 4073
RoboRealm Propeller MCU Examples / Help Needed
Well I’ve gotten this far with my Robo Magellan project: ...
13 year 17 4982
MIN_X and MIN_Y issues when calculating distance to the COG
HI, I am using roborealm to find the maximum distance of the COG of an object to either top,bottom,right or left to decide the d...
14 year 2 4301
Image filename
Hello Roborealm How is it possible to display an image filenmae on the Robo screen. ...
17 year 2 4236
Crop and Scale modules don\'t change IMAGE_WIDTH variable
Hi STeven, Using RR version 2.5.9, I noticed that when I Crop a 320x240 image to a lesser width, sa...
17 year 11 5406
