Point Location
The Point Location module provides a quick way to identify specific coordinates within the image based on their location. For example, you may want to know the position of the highest point of any non-black pixel within the image to identify a maximum peak. Note that this module operates on a binary image.The module is often used after numerous morphological operations that have thresholded the image and changed the image shape.
Note that the north, south, east, and west points are calculated relative to the object's Center of Gravity point.
1. Location - Select each point that you would like to indicate with the image. Note that for each point a variable with a similar name is created with the X and Y coordinates of the point.
2. X,Y - Once Nearest X,Y and/or Furthest X,Y is selected the X and Y coordinate text boxes will be enabled. You can specify the X and Y coordinates of the point that should be used when comparing for furthest and nearest object points to the specified point. Keep in mind that the [expression] notation also applies in the text boxes.
3. Shape - The shape of the marker that indicates where a point has been sampled.
4. Color - The color of the marker that indicates where a point has been sampled.
5. Size - The size of the marker.
| Leftmost, Rightmost and highest points indicated in red X |
Variables
HIGHEST_LEFTMOST_X HIGHEST_LEFTMOST_Y HIGHEST_MIDDLE_X HIGHEST_MIDDLE_Y HIGHEST_RIGHTMOST_X HIGHEST_RIGHTMOST_Y LEFTMOST_HIGHEST_X LEFTMOST_HIGHEST_Y LEFTMOST_MIDDLE_X LEFTMOST_MIDDLE_Y LEFTMOST_LOWEST_X LEFTMOST_LOWEST_Y LOWEST_LEFTMOST_X LOWEST_LEFTMOST_Y LOWEST_MIDDLE_X LOWEST_MIDDLE_Y LOWEST_RIGHTMOST_X LOWEST_RIGHTMOST_Y RIGHTMOST_HIGHEST_X RIGHTMOST_HIGHEST_Y RIGHTMOST_MIDDLE_X RIGHTMOST_MIDDLE_Y RIGHTMOST_LOWEST_X RIGHTMOST_LOWEST_Y NORTHEAST_X NORTHEAST_Y NORTHWEST_X NORTHWEST_Y SOUTHEAST_X SOUTHEAST_Y SOUTHWEST_X SOUTHWEST_Y FURTHEST_X FURTHEST_Y NEAREST_X NEAREST_Y
Sample Line
Sample Curve
Ultimate Points
| New Post |
| Point_Location Related Forum Posts | Last post | Posts | Views |
Hi, Using the Visual Targeting tutorial found on ... |
11 year | 2 | 4296 |
I have a 6-axis anthropomorphic robot performing some very detailed & intricate wood-carving. There is some error in ... |
12 year | 3 | 4044 |
Hi STeven, I attached an image here. I want to extract the point X=347 Y=13. If i extract the blobs... |
14 year | 5 | 4392 |
Steven, I have been testing the software, and it looks that covers my needs. | 16 year | 6 | 5043 |
