Blob Separate
The Blob Separate module is used to separate blobs of different colors into distinct objects such that they can be processed as individual blobs by the morphological routines which assume a binary colored image. For instance, if an image is segmented into colored blobs simply by reducing the number of colors used there will be many blobs that touch each other. Applying a morphological module like "erode" will assume that all non-black pixels constitute a single blob of connected pixels. Using the blob separate module prior to the erode module will ensure that the erode module treats each differently colored blobs as a separate entity.
1. Insert the separate blob module. Blobs of similar colors will be separated from other colored blobs by a black line
SourceBlob Separated after Flood Fill
Flood Fill
Border
