Neato XVLidar
The Neato XVLidar module provides an interface to the XVLidar embeeded within a Neato vaccum robot. The XVLidar is a low cost lidar sensor suitable for indoor robotic SLAM application. It provides 360 degree scan field, 5.5hz rotating frequency with a 10 - 15 foot distance. XVLidar is the ideal sensor in cost sensitive areas like consumer robotics and hardware hobbyists.
This module assumes that the Get Surreal XV Lidar Controller is used to connect a PC via serial to an XV Lidar.
1. COM Port - Specify which COM port the XVLidar is attached to. Once connected the Green connection bar will show.
2. Remember As Default - Select the "Remember as Default" checkbox if you would like the current COM setting to be remembered by RoboRealm such that whenever the lidar is loaded the COM port will be auto-selected. This ability allows you to not have to constantly change the COM port when loading in successive RoboRealm configurations.
3. Filter - To smooth out the signal and avoid gaps you can smooth the distance values coming in from the lidar within their local neighborhood. Thus noisy spikes are reduced as their previous and next angular measurements are averaged into each value.
4. Display Zoom - Select how much zoom to apply to the current view. Auto will detect the furthest object and scale the display accordingly. This may cause the map to jump in scale as distant parts are typically noisy.
5. Display Fill - Check if you want the graphic to be filled with the specified color as apposed to an outline.
6. Display Chart Type - Select how you want the values to be displayed.
Radial - Displays the range points connected as you would expect them to be seen in reality. Note that areas perpendicular to the sensor are connected despite no actual values being present. (i.e. changes in depth are connected between values).
Cartesian - Displays the range values in a traditional XY chart.
Intensity - Displays the range values as a single row with intensity values based on actual range. Brighter objects are closer.
Points - Displays the raw points as received from the laser scanner.
7. Display Color - Select the color you want the graphic display to use.
8. Graphic Size - Select the line, or point size that should be used when displaying the graphic.
9. Average Statistic - Select if you want a variable to be created that indicates the average of all the range data.
10. Maximum Statistics - Select if you want a variable to be created that indicates the maximum distance within the range data.
11. Minimum Statistics - Select if you want a variable to be created that indicates the minimum distance within the range data.
Variables
NEATO_XVLIDAR_POINTS - the distance points as returned by the XVLidar device
NEATO_XVLIDAR_AVERAGE_VALUE - average value of all the range data
NEATO_XVLIDAR_AVERAGE_ANGLE - average angle of all the range data
NEATO_XVLIDAR_MINIMUM_VALUE - the minimum value detected in all the range data
NEATO_XVLIDAR_MINIMUM_ANGLE - the angle towards the minimum detected value
NEATO_XVLIDAR_MAXIMUM_VALUE - the maximum value detected in all the range data
NEATO_XVLIDAR_MAXIMUM_ANGLE - the angle towards the maximum detected value
Markers
Neato_XVLidar_Graphic - graphic shown in GUI
Hokuyo URG
Laser Line
For more information
Neato Website
Get Surreal Website
 New Post
Neato_XVLidar Related Forum PostsLast postPostsViews
Neato Lidar module - functional? data format?
I am attempting to use the Neato lidar module. I do not have the GetSurreal controller but I ported the GetSurreal...
10 year 4 3483
