Combine RGB
The Combine RGB provides you with a way to create an RGB color image based on different image channels. This means you can separate an image into individual channels, filter the channels separately and then recombine those processed channels into a new image.
1. Select the source images to use for each channel
2. Select which channel in the specified source image the data will be grabbed from
SourceCombined RGB without Saturation
Click here to download the robo-file that sets the saturation to zero in an image. This process essentially turns green and red objects into a nice blue!
Math
