using ip camera "onvif protocol" as camera source moods from Lebanon [5 posts] |
Is there any way to let roborealm use my ip camera as camera source ?
Which camera do you have?
We can add an ONVIF module to communicate directly to those supported cameras. In your case, we are just wondering if you need pan/tilt commands too.
The camera I have is not listed. But it support onvif which is a general protocol used by almost all ip camera's manufacturers now a days. Is there a way that I can maybe convert an ip camera into a recognizable usb camera or stream directly from it into roborealm ?
Yes, the Read_HTTP can be used with IP cameras that have an MJPEG stream. The url that you need to use can sometimes be found online or from the web interface for the camera itself. This url typically ends with .cgi but is different for each camera.
http://www.roborealm.com/help/HTTP_Read.php
