Roborealm not recognizing multiple Playstation Eye cameras
Hello all,
I am trying to use 3D Viewer to handle inputs from the two Playstation Eye cameras I have. However, Roborealm is not recognizing the fact that "Playstation Eye" is two separate cameras. It will only allow the image from one camera at a time to be displayed/manipulated.
I went into the Windows registry editor and changed both the name and the description of each camera-but no luck. Perhaps Roborealm is recognizing the same driver software for both cameras?
Anyways, as I am still relatively new to Roborealm I was wondering what more experienced users had to say/if they've encountered a problem similar to this.
Thanks.
I assume that you installed the code lab drivers? Note that you need the platform SDK driver in order to access two.
Can you confirm that you are using the right driver?
You also need to use the Code Lab module to access both.
http://www.roborealm.com/help/Code_Labratories_Playstation_Eye.php
