Audio Anonymous |
Hi.
I have a problem with the audio. For example, when I include a format. Wav or beep in a state if .. and run the program, the audio is repeated all the time. I find the way that is heard only once.
I do not want the state to produce an infinite loop. When you enter the ring only been once, but keep the program running.
Thanks.
You probably need to surround the audio playing with an if statement module and ensure that the latch checkbox is selected. This will then play the audio only once when the condition of the if statement changes.
Without this if statement the audio will play each time the pipeline is evaluated.
Hi Steven.
This is my VBScript program to reproduce de audio file .wav. The problem is
when the program enters (if objecte = 1 then), the audio plays but to move to another if objecte = 0 the audio continues to play. The other audio chimes.wav not reproduce does not play until you finish the other.
I like it when it changes state directly change the audio.
objecte = GetVariable("MOUSE_X")
if objecte = 1 then
Set objVoice1 = CreateObject("SAPI.SpVoice")
Set objFile1 = CreateObject("SAPI.SpFileStream.1")
objFile1.Open "C:\Windows\Media\vientocentral.wav "
objVoice1.Speakstream objFile1
end if
if objecte = 0 then
Set objVoice2 = CreateObject("SAPI.SpVoice")
Set objFile2 = CreateObject("SAPI.SpFileStream.1")
objFile2.Open "C:\Windows\Media\chimes.wav"
objVoice2.Speakstream objFile2
end if
I'm not sure you want to trigger off from MOUSE_X as that will change based on the position of the mouse. Is this correct?
The way audio works is that it will play to completion even if you try to change the audio file ... so you want to use very short busts of audio (preferably a single tone) that will end quickly without overlapping with the next tone. Thus I'd recommend using the Beep module more than the audio play module (or your VBScript alternative).
