help
Its sort of inerfacing... my listen function won't work. when i try to use it, it says "Listen Module failed at CreateRecoContext!". Does anyone know why it is doing this and how I can fix it.
That is the second check done by the listen module to ensure that the speech system is correctly working. It is most likely caused by having a previous version of the MS Speech SDK. Make sure you have version 5.0 or above and try the module again. See the doc page for where to get that.
http://www.roborealm.com/help/Listen.php
