defect detection
Sandeep Kumar Jain from India  [4 posts]
hi  i want to know how to find defects in component using robo realm?   that say if i have a watch without any defect and a watch with defect   i want to compare both and find out where is the defect?
Can you post both images here?
You can either use the Math module to subtract one image from the other or the Movement module if you have many images to compare to a base image ... either module will allow you to highlight the difference between the two images. Note that you might need to align the images and adjust for lighting before comparing ... seeing the images will help us know if that is needed or not.
http://www.roborealm.com/help/Math.php
http://www.roborealm.com/help/Movement.php
