Sample_line Saikumar. from India [20 posts] |
Its been cool going with RR, hope you ve been doing fine too :)
Well reg Sample_line function, is it possible to get the cordinates of the samples?
I would like to use these samples to make a simple line follower :P besides using pathplanning.
Thankyou verymuch.
Saikumar.
Saikumar,
Yes, a variable called SAMPLE_LINE_POINTS is created (use the Watch module to see all variables) that includes the points of the sampled line. Is that what you were looking for?
oops! should have checked the documentation.
and yes, thats what I wanted.
Thanks Steve.
Well Steve,
The real part is, I need to make a b&w sketch of a photograph[face only].
What i want is only a single dark line, so that I use this Sample_line to produce the required array.
Then i wd like my bot to sketch it on sheet using pathplanning and that array. Well the pen up-pen down is a secndy headache.
Plz do help Steve,[might be topic name dosen sound apt for ths prob]
Thankyou.
Sounds like fun! Good luck ...
Also, please check your text before posting as it seems you are missing a couple of characters in your post which makes it hard to understand.
