vbscript
Fax from Estonia  [1 posts]
I´m using this code:
x = GetVariable("HIGHEST_MIDDLE_X")
midx = GetVariable("IMAGE_WIDTH") / 2
leftThreshold = midx - 50
rightThreshold = midx + 50
if x <= leftThreshold then
  SetVariable "left_motor", 0
  SetVariable "right_motor", 255
else
  if x >= rightThreshold then
    SetVariable "left_motor", 255
    SetVariable "right_motor", 0
  else
  end if
end if
And i have a problem.
What i need:
if:   SetVariable "left_motor", 0
i need to send key R
And if
i need to send key L
I have tried putting some vbscript sendkey commands what i found from google. Like:
objShell.SendKeys "L"
But these dont work.
I´m not very good at coding these languages. Wish it would use php.
Fax from Estonia  [1 posts] 17 year
Bump. Thanks.
Ok, try using
  SetVariable "key_to_send", "R"
else
  SetVariable "key_to_send", "L"
  else
    SetVariable "key_to_send", ""
  end if
end if
and then in the key_to_send variable in the Keyboard_Send module
http://www.roborealm.com/help/Keyboard_Send.php
I.e. the variable created above has the value to use in the Keyboard_Send module. Think of the VBScript as creating parameters for other modules that are then specified using the GUI. So by changing the variable you change what keys are sent.
Make sense?
