serial communication
mariam from Egypt  [2 posts]
hi, how we can use serial communication for sending data to serial port
after determine the ball & robot position using center of gravity
Have a look at the serial module
http://www.roborealm.com/help/Serial.php
and type in something like
\[cog_x]\[cog_y]
into the send sequence assuming that cog_x and cog_y are valid variables. Note that two bytes ranging from 0-255 will be sent. If you need a higher range use
\\[cog_x]\\[cog_y]
which will send 8 bytes total (4 bytes per number).
