Surface Gradient
The Surface Gradient module provides a way to highlight the intensity gradient within an image. Often
due to shadows and other lighting distortions the actual intensity value of an object can change. The
gradient or direction caused by the intrinsic intensity of color of the object stays relatively the
same under these circumstance. Using the Surface Gradient module it is possible to highlight
gradients of a specific angle that can be used for successive processing.
A surface gradient is similar to an edge but instead operates specifically on the
direction of the slope of that edge. Instead of generating a high pixel value when a high transition (
like white to black) occurs as is done in an edge detection routine the Surface
Gradient module looks at the normal of the planar surface created by that same edge. Thus
a direction of gradient (0 - 360) becomes the most relevant result of gradient detection. Note that
even edges that are small in transition (i.e. gray to black) will still cause a planar
surface with a gradient at a particular direction. This ability is one of the Surface
Gradient's advantage over the edge detector in that it is not as dependant on actual
image intensity.
1. Gradient Direction - Specify the gradient's degree that you want to highlight. This is not
unlike adjusting the desired lighting direction to highlight a particular gradient. For example,
specifying 90 will cause those surface areas of a gradient of 90 to become mostly white (255)
with other gradients further from 90 degrees being represented with a darker intensity.
2. Blur - To reduce noise within the image it is recommended to blur the image slightly. This
will help to reduce the spurious surface gradients caused mostly by noise and produce a smoother
gradient image.
3. Noise Filter - To further reduce gradients whose angles are created from low intensity
gradients you can set a gradient threshold to exclude those surface patches whose
gradient vector strength is not significant. Increasing the noise filter value will cause only those
gradients with high a high intensity shift to be considered. Note this value depends on the
intensity of the image and thus is not invarient to intensity changes.
4. Surface Patch - To average a gradient over a larger patch size in order to smooth the
gradient you can increase the gradient patch size under consideration. Increasing this
value has a similar effect to increasing the blur but has a more accurate representation
but at the cost of CPU processing.
| Source | Surface Gradient |
The example above shows how the steps can be highlighted using a gradient of 180 or 0. This image
can then be thresholded to better isolate the staircase.
Sobel Edge
