Salt & Pepper
The Salt and Pepper filter will remove "hotspots" in the image. Hotspots are defined as those pixels whose intensity values are abnormally higher (salt) or lower (pepper) than the immediate surrounding. The filter will determine what the average intensity is around a particular pixel and then based on a similarity set the pixel to that average value if the pixels value is above that similarity threshold.This filter is most useful in astronomic images that contain noise from long exposure CCD devices.
1. Speck Size - Select the speck size that you want to remove from the image.
2. Sensitivity - Select how much a suspect pixel needs to be different from the neighborhood mean to be considered a speck. The smaller the number the more sensitive it will be. At a level of 1 the filter will act as a mean filter, at 255 the filter will produce minimal change.
| Source | Salt & Pepper |
Median
Mean
For more information
Salt and Pepper Noise - Wikipedia
| New Post |
| Salt_Pepper Related Forum Posts | Last post | Posts | Views |
How to launch second simultaneous instance of RR?
I have two RR files, A and B. I wish to run A, and use the Execute Program module from within RR to launch robofile B. I want B ... |
11 year | 5 | 3387 |
