Lab Channel
The Lab Channel module provides a way to convert to and from the CIE-L*ab color space. The Lab color space converts a pixels light into the L channel with a and b being color channels.
1. Specify the transform to apply to the current image
L - The L dimension of the Lab color space
a - The a dimension of the Lab color space
b - The b dimension of the Lab color space
Lab as RGB - convert the current image into Lab color space and apply each of the Lab channels into the RGB channels
RGB as Lab - convert from Lab space into RGB space by assuming that the current RGB image includes Lab color space data.
SourceLab as RGB
XYZ Channel
YCbCr Channel
HLS Channel
RGB Channel
For more information
Wikipedia Lab Color
Easy RGB Color Conversion Algorithms
 New Post
Lab_Channel Related Forum PostsLast postPostsViews
A question about the LAB_Channel module
Hello, I need to use the L, a and b values from the LAB_Channel module as inputs to an artificial n...
16 year 3 4422
