Default Variables
Several default variables are added once the pipeline begins execution that hold information
valid for the current instance of RoboRealm running.
CAMERA_NAME - the name of the usb/VFW/DirectX camera that you are currently connected to
CAMERA_PATH - the usb device path of the camera that you are currently connected to
IMAGE_PATH - the current path/name of the currently loaded image (assumes webcam is not active)
IMAGE_FILENAME - the current image filename loaded
IMAGE_COUNT - the captured image count or number of frames before being processed
IMAGE_WIDTH - the current image width (note some modules like Scale will change this)
IMAGE_HEIGHT - the current height of the image
IMAGE_PROCESSED - the captured image count or number of frames after being processed
IMAGE_TIME - the time that the image was captured
IMAGE_DATETIME - the date and time that the image was captured
FPS - the current Frames Per Second being processed
LOADED_IMAGE_SCALE - the maximum image size is 6400x4800. If an image is larger than
this size it will be scaled to at or below 6400x4800. When this happens this variable
will reflect the scale applied to the image (less than 1.0) to ensure it is below
these width and height requirements.
POWER_DEVICE - either "AC" or "BATTERY" which indicates if your laptop is on AC or Battery
power
POWER_CHARGE - either "HIGH", "LOW", "CRITICAL", or "CHARGING"
POWER_LIFE_PERCENT - 0 to 100 value that indicates how charged your battery is
POWER_LIFE_TIME - estimated number of seconds of battery life left
PROCESS_TIME - number of milliseconds the last image frame took to be
processed (in increments of 16 milliseconds).
MOUSE_CLICK - "1" if the mouse is clicked otherwise "0"
MOUSE_CLICK_X - the X coordinate of where the user mouse last clicked on main image preview
MOUSE_CLICK_Y - the Y coordinate of where the user mouse last clicked on main image preview
MOUSE_CLICK_TIME - the time (seconds) of the last user click
WIRELESS_STRENGTH - the strength of your current wireless connection. Ranges from 0 to 100.
