Convex Hull
The convex hull module will transform a binary blob into its convex hull. The convex hull of a binary blob is the shape formed if a rubber band were wrapped around the "outside" points of the blob. More specifically any angle formed by three perimeter points must be less than 180 degrees for a convex hull to be formed.
The convex hull is useful when you want to simplify the shape of a binary blob by simplifying the perimeter.
SourceConvex Hull
Smooth Hull
For more information
Wikipedia - Convex Hull
Graham's Scan
 New Post
Convex_Hull Related Forum PostsLast postPostsViews
Camera Freezing with Convex Hull
I am having problems with Roborealm locking up on a live image when using the Convex_hull method.  The symptoms are th...
10 year 4 3703
