Distributor Client and Server do not maintain connection Brett from New Zealand
3 year
I saw a couple of posts that described having problems with the distributor and client when using the "Request Variables" option by itself. The connection would connect and disconnect almost between every transfer. Code: (1)
I found that the problem was that I had my Distributor Client module was after a Timer module.
Moving the Timer to the end mostly solved this problem. I still had some disconnections, but not nearly as many.
