You are correct in your usage of the Set_Variable module. That would be the way to "rename" a variable to another name such that the value is not overwritten. You must be sure, however, to use the correct expression in the Set_Variable module to do this. For example, in the Sample_Color module the variable COLOR_SAMPLE_R is create. In Set_Variable you would use
new_r [COLOR_SAMPLE_R]
but NOT select the IsArray checkbox ... that's only for when you specify a list of values in a comma separated list that you want converted into an array.
See attached example.
