Yes, this is possible. You can change the name of the filename that is created using by placing [my_filename] in place of c:\path\to\filename.avi in the Write Avi module. This means that the filename is now controlled by the variable my_filename .. which you can change in a scripting module to whatever name you want. It will know that when the filename changes to close the old one.
See attached for a simple example on creating TestX.avi filenames. Press the button to move to a new video filename. Note it assumes c:\temp\ folder exists.
