They are quite comfortable in terms of performance. The actual frame rate will depend on what modules you are using. If you want you can post a robofile and I can test on both systems with an external logitech camera capable of 30fps to see how they compare. If you post the robofile you used with the PI I can try that with a 640x480 resolution which will give a reasonable comparison with the PI.
