I am using RoboRealm with a DFK ECU010-M12 camera. This camera uses the compression format YUY2. I am successfully able to set this as the format when in RoboRealm by using the options menu.
I am trying to connect to the camera using the RoboRealm API or DLL. Thus, I am trying to set this format using the set camera format command. When I issue this command, I have been unable to get the format to change. The command is able to change the size and frame rate of the processing but does not change the format.
Could you please advise on why this might be or how to proceed. Thanks!
