Add to this Thread
Those are probably the two main modules that you would want to use. Note the checkbox on the movement module that helps to eliminate global movement. This is required when the camera is moving as the entire scene will change and not just isolate the movement of the person. Note that this assumes enough of the image in view is stationary in order to work correctly.
I would also use a mean filter just before the movement module just to reduce any noisy pixels that could cause errors.
Pick Avatar
* Question/Comment - Only <b>, <i>, <u> tags are allowed. All others will be escaped.
Use the tags [image1], [image2], etc. to place the images within your question/comment.
Upload Images (.jpg, .png, .gif) < 300K, robofiles (.robo) or Zip files (.zip) < 300K.
If you have any questions/issues about RoboRealm or image processing this is your chance to ask a question. Your question and any responses will be posted to the forum section of the website for others to read and learn from.
Note that any submission will be considered property of RoboRealm. If you do not wish your images to be displayed as part of the RoboRealm site please do not submit those images. Any submission may be removed from the website at the discretion of RoboRealm personnel.
