Add to this Thread
Vijayakumar,
Use the If_statement module and place it around the Write_Image module. Press the Start button in the write image module.
Now it is under control of the if_statement module. If the condition (using your variable) is false it will not execute the write image module. Note that on saving and reloading the start button will still be pressed.
Basically, you use the If_Statement to determine if you will or will not execute the write image module. Does this make sense?
Pick Avatar
* Question/Comment - Only <b>, <i>, <u> tags are allowed. All others will be escaped.
Use the tags [image1], [image2], etc. to place the images within your question/comment.
Upload Images (.jpg, .png, .gif) < 300K, robofiles (.robo) or Zip files (.zip) < 300K.
If you have any questions/issues about RoboRealm or image processing this is your chance to ask a question. Your question and any responses will be posted to the forum section of the website for others to read and learn from.
Note that any submission will be considered property of RoboRealm. If you do not wish your images to be displayed as part of the RoboRealm site please do not submit those images. Any submission may be removed from the website at the discretion of RoboRealm personnel.
