Changing webcam resolution Kris from Netherlands [1 posts] |
Does anyone have an idea how to change the webcam resolution by using the Programming API? The default is 320x240, but for my application I need the 640x480 resolution. I can't find anything about it on the web.
Kris,
If you change the resolution in the application and then exit it should remember the resolution last used and use that one on successive executions. Are you seeing a different behavior?
Currently there is no way to change the resolution using the API. But that's something we can add in if needed.
