SetTimedVariable_ Have anynoe used it?
Denis from Puerto Rico  [2 posts]
RoboRealm Rules.
Have anyone tried the SetTimedVariable statement??
For some unexplained reason if I input a timeout value > 46 it will take forever to reset the value.
Any Ideas??
Denis,
Can you post your robo-file and we'll check it out. The SetTimedVariable is quite new so there is a definite possibility that something may not be working very well.
SetTimedVariable Robo File
It looks like I already fixed the really weird problem I mentioned before.  However, the SetTimedVariable timeout parameter its not accurate at all.  Now that I have experimented with it a little bit, it seems that the timeout takes twice the time it should.  Also, the time intervals are not consistent.  Here is a copy of the robo file, so you can check my prog flaws.
if GetVariable("k") = 1 then
  SetVariable "k2",0
  SetTimedVariable "k2",1,5000
  SetVariable "k",0
end if
if GetVariable("k2") = 1 then
if GetVariable("COG_X") < 54 then
  SetVariable "move", 4
  SetTimedVariable "move",0,300
elseif GetVariable("COG_X") > 190 then
  SetVariable "move",8
end if
if GetVariable("COG_Y") > 190 then
  SetVariable "move", GetVariable("move") OR 2
elseif GetVariable("COG_Y") < 58 then
  SetVariable "move", GetVariable("move") OR 1
end if
SetVariable "k",1
end if
