Problem with Horizontal Mirror and COG
Javier Fuentes from Spain  [4 posts]
The video source that I  use is reflected horizontally, so I use Horizontal Mirror Module to correct this defect. But the problem arises when I add the Center of gravity module with the option to overlay graphics in the source image and it appears to me the inverted COG as in the original image and without having in account the Horizontal Mirror module that already I've added.
There is some form of which the COG is considering the applied horizontal mirror transformation?
Problem solved
Problem solved!
As simple as to add a second Horizontal Mirror Transformation Module after the COG module with the overlay graphics on source image checked.
