'while' loop in VBScript Program Anonymous |
What is the right way of coding a 'while loop' in the VBScript Program? I would like the program to wait (loop) while the condition is not true (e.g. keyboard key press, 'P' for example).
When programming in the VBScript module you have to remember that you are already in a loop. Each new frame causes the loop to process again. If you prevent the ending of the loop by putting a while loop in the VBScript it will not allow the system to capture new images and continue processing.
So, the way that you accomplish this is to write conditional statements around variables that maintain what state you are in. In the case of the keyboard you would use a conditional to check for a keypress each time the VBScript is run and perform an action based on that.
Good point Steven.
I just wanted to pause the program until some key is pressed, using the 'while loop'. Is that possible anyway? If not, that's ok.
Cheers
Yes, you can.
Use the if statement to check to see if the key has been pressed. See the example included below which waits for the CTRL-z key being pressed before the RGB_Filter module is allowed to run.
