Timer values
from Australia  [87 posts]
I would like to know the time between the two event's (e.g. mouse clicks). Is there a feature like 'Timer' available from where the software could read the current time so that it can compare it to the previous value.
Anonymous 19 year
Yes, that is possible. In the next release 1.7.9 (due out in a couple hours) you can use the following code inside a VBScript module.
timestamp = GetVariable("MOUSE_CLICK_TIME")
if timestamp <> 0 then
  last = GetVariable("LAST_CLICK")
  if last <> 0 then
    write "Time Difference: " & timestamp - last
  end if
  SetVariable "LAST_CLICK", timestamp
end if
or see the robo-file below. Note that these variables are set when a user clicks on the main RoboRealm image. The timing is in seconds. You also have the variables MOUSE_CLICK_X and MOUSE_CLICK_Y which represent the location that the user clicked on. Watch the Watch_Variables module to see how these are set/removed on user interaction.
