Bug with using variable in Write_Text variable Tim from United States [9 posts] |
9 year
I have set up a variable for a path I want to write text to, but the [variable] does not seem to work with the write_text module, i use the same variable with the same syntax when using write_variable, and it works?
Am I doing something wrong??
thanks in advance.
9 year
Tim,
That module wasn't updated to accomidate the [variable] expression in its filename. It was created before those expressions existed.
This has been updated. If you download the latest version it should operate as expected.
9 year
STeven, Works Great now, Thank you so much!
