Background Removal from Malaysia [14 posts] |
9 year
i wanted ignore the surrounding circular area of the mirror using circle module, but i can't to replace the circle blob to source inside the white blob.
9 year
Use the Math module with an AND function using the mask image and the original image as the two image selections. What this does is to allow only those pixels to persist where the white area is.
Note, you may need to save the circle image as a Marker before you will see it in the dropdown ... depending on how you arrange things.
9 year
thanks steven.. it working :)
