Movement Strobe use
Josh from United States  [1 posts]
9 year
When I run a robo file (such as the example file) roborealm shuts down immediately. I'm on version 2.83.17
Josh,
Not sure if you included a robofile or not but it seems to be missing in the post.
Also, please update to the latest version as there was an update to that module after the version you are using.
You should also have had a crash report popup? If so, please submit those as they are VERY helpful to determine the issue and will save you and us a lot of time. Sometimes these are not generated so they will not always happen but if they are, please do submit them.
