Unable to Add RoboRealm.dll to C# project JHao from United States [10 posts] |
9 year
I am trying to explore RoboRealm.dll. I created a C# project and then try to add RoboRealm.dll to my project. It gives me an error message "A refernce to 'C:\Program Files\RoboRealm\RoboRealm.dll' could not be added. Please make sure that the file is accessible, and that it is a valid assembly or COM component".
Could you let me know what happened?
9 year
JHao,
You don't add the dll to the project like you would in C++. Instead, you need to use it via the COM object. Download
and refer to the included C# project. With one command you switch between the API and DLL. I *highly* recommend first using the API since you can then see what RR is doing and then move to the DLL afterwards.
