Server processing of images Paul D from Canada [45 posts] |
9 year
Hello STeven,
I am starting an inspection project which is better suited as a RR server application with no camera attached.
Can the Web Server module be used for clients to submit pictures and receive and XLM response with post-processing variables? I am looking for a simple pass/fail response on a single image.
I could also write an asp.net script to handle the client connections, receive the images and communicate with RR.
Thanks for the help.
8 year
Paul,
This is possible but a lot of it will depend on what platform your clients would use to submit pictures. For example, are they sitting at a laptop/desktop or are they on a mobile phone? The reason is that uploading an image to a webserver has never been very standardized and there are a lot of helper objects that can help make the upload a bit easier but they differ in how they send the data. Do you have one of these in mind or where you just looking for a simple upload button not unlike what we use in the forum to upload images?
Keep in mind that RR doesn't run any back end web scripting like ASP.net/PHP/etc. does so its functionality in hosting a web app will be very limited. You may find that using the API to a .net webapp might be more flexible and use RR as you would use a database in a webapp (i.e. server side API calls).
