numbers vs strings Mal from United States [3 posts] |
9 year
I am trying to control motors with a microbasic ARC32. The problem is when I send wheel speed info over serial, RR sends strings not actual numbers. The ARC 32 has no syntax to convert the string values to actual number values. Is there a way to make RR send numbers instead of strings. If not then do you have any suggestions. I need to verify I can do this before I purchase RR. Thanks
9 year
Mal,
Yes, instead of
[IMAGE_COUNT]
in the send field use
\[IMAGE_COUNT]
for a single byte number from 0 to 255 and
\[IMAGE_COUNT]
for a two byte number. You can read about this (linked from the Serial module documentation at)
http://www.roborealm.com/help/Text_Formats.php
9 year
Thank you Steven. Actually I found the solution to my problem. The ARC32 language actually does have a command to input strings as numerical values. I just couldn't see it although it was right under my nose. I had tried it but didn't realize that it had to be in all capitals to work...and stupid me was using lower case. Oh well, it's all a challenge and learning lesson.
Mal
