Remove shadow of the sample image Allen Lin from Taiwan [6 posts] |
Dear sir,
The sample image was taken by a linear scan CCD and it was default grey scale image , the canyon of the working piece had some shadow due to the height of the piece.
I try to remove the shadow by the way as attach robo file . The result is effected by the Normalize Color level and can't make sure we get the right distance of the
It there some modules or filters that can remove the shadow but still keep the real edge of the working piece??
The final result should be 4.076mm, scale factor is 1 pix = 0.0035 mm that was got by a 3D coordinate measuring machine .
Thanks.
Allen
Allen,
Can you post your original unrotated image? The robofile was blank but we are more interested in the raw image.
Also, can you manually label what edge you want to identify? Its not clear from the images which one you are talking about. I think you may just ignore the shadows and instead detect the edge given the presence of the shadow. So that would not require the removal of the shadow but just work around it.
Sorry for that. I attached the Robo file and the original picture. I placed two lines to indicated the edges of the pieces in Robo and commented as line #1 and line #2.
Thanks.
The BMP format can't be uploaded and save them as JPEG format.
Thanks.
It is strange it didn't save the content of the Robo on Win10 X64. I use another way to save the file.
Allen,
Can you confirm that you uploaded the right image with line#1 and line#2 annotation? I'm not seeing that particular image. It looks like 2 original raw images as apposed to 1 raw and 1 with annotation.
thanks,
I 've embedded those lines in Robo file , and I done a screen shoot for your reference.
I repacked the Robo with image, that will be easier to see.
I also repacked the org image, so they will keep in BMP format.
temp.zip
Allen,
Attached is another way to get those line edges. The result is close but not perfect since it is really sensitive and will probably return a different result on a live image. You may need a higher resolution camera to get the precision that you are looking for.
Note, you will probably need the latest version of RR for the attached robofile to work.
