Servo AX dynamixel is not moving Nurul Fuad from Australia [13 posts] |
Hi Steven,
Currently, I have problem in connecting AX 12 Dynamixel servo. The servo is being recognized by RR however, when I did some programming to turn servo into certain angle, it did not work.
I use VBS script function.
This is my program that I have made and use the mean intensity value to move the servo.
___________________________________________________________________
'Get servo variables
meanIntensity = GetVariable ("MEAN_INTENSITY")
SetVariable "CENTRE", 512
'Servo rotate according to mean intensity value
if meanIntensity < 126 then
Position_New= CENTRE + 100
end if
SetVariable "Position_New", Position_New
Questions:
1. What are the possible reasons for the servo is not moving?
2. Do I have to everytime check on the Robotis Dynamixel function before doing any programming coding in VBS script?
3. Does the coding above is correct?
Your help are highly appreciated.
Nurul,
There are a couple mistakes in the script that you included. I think there might be some confusion with regards to the memory space of the VBScript module and the memory of RR. Since the VBScript runs in its own space it needs to use the Get and Set Variable functions to move data into and out of RR space. Without that setting or getting the information will not move correctly into RR. I think what you want to use is
Position_New= 512 + 100
else
Position_New= 512 - 100
end if
since the CENTRE variable is not being set as a VBScript variable. I assume you are using Position_New variable in the Dynamixel module right?
