Applying Green Fileter Aman Rana from United States [37 posts] |
Hello, We are trying to apply a Green Filter. After we change the pixels we don't see that reflected in the image.
Aman,
You need to add
SetPixels pixels
at the bottom of that VBScript program to send the changes back into the processing pipeline. You are working on a copy of the image in VB so changing that will not change the image in RR.
You may, however, look at the RGB_Filter module which does something similar to what you are doing in VB. The VB processing will work but it will be MUCH slower than a C++ module (which is what RR is written in).
