software not respondig Anonymous [11 posts] |
dear sir
As a robot enthusiast, ROBOREALM is a fantastic software I found. But roborealm crashes seamlessly i my pc ( stuck and not respond) . please explain me the best way to keep it stable in my computer. (most suitable version of window or pc that it run stable) my pc is 64 bit windows 7.
The best way to ensure stability is to send us those crash reports that should appear after a crash. Since RR is used in many different ways and in many different environments the crash reports are your best way to ensure that something that might be different in your environment is brought to our attention.
Also, note, in case you are using the 64bit version that is still in beta and not as stable as the 32 bit version.
If you don't see a crash report (typically on your desktop) send us the robofile you are using so that we can check that too. Often when a report is not generated its the camera drivers that are causing issues so updating those is a good idea too.
