Write images
Hi STeven
Is there a simple way to initialise the saved image number in 'write images'?
Hopefully also keep the 6 digits in the filename with leading zero's
I get an error as seen, unless I'm doing it wrong.
Is the start value an accessible system variable?
Regards
Roland
Me testing from Atlantic Ocean  [274 posts] 11 year
Roland,
That particular value wasn't able to understand a variable ... so that has been fixed. You can now use [variable] in that field to specify a different start number. 6 digits will still be used.
Note, you can also use [variable] in the filename field and use some other scripting module to create that variable filename if you need even more control.
