hardware needed
Elios  [1 posts]
Hi Steven,
We would like to know what hardware needed to process the Real-Time stabilizer and is there any document which explain how to do it?
It should just function fine on a regular PC unless you have a large video image (> 640x480). See
http://www.roborealm.com/help/Stabilize.php
and in particular the "Click here" text that will download an example robofile that you can run in RR. You will have to edit the Media_Reader module to specify the correct path of your video.
This example shows both the original and then stabilized video to give you a good idea on what is going on.
