Arduino Uno R3 - Sparkfun Patrick Poirier from Canada [2 posts] |
I am starting experimenting with Arduino Uno R3 and the Sparkfun Arduino interface.
I can control the digital and analog IO bit i cannot get any pulse whith the PWM sliders. I tested with a simple servo libray example and it is working fine. Any suggestion ?
Patrick,
Can you download the Arduino code again and upload to the Arduino ... there was a test statement in the beginning of the main loop which was stopping the code from working.
I don't think the digital nor analog were working either. Not sure why you thought they were because they were also disabled.
http://www.roborealm.com/help/RoboRealm_Arduino/RoboRealm_Arduino.pde
Thank's Steven for the reply.
I had downloaded the same code than the one you are refering to. My problem was related to the servo library wich was somehow corrupted. I reloaded the library and the code is working fine now.
Thank you for your support and keep on the good work , ROBOREALM is a great product for experimenters, it really save a lot of time on buiding prototypes and the tools available makes it so easy to play with.
