SHAPES array Jeremy from United States [12 posts] |
When using the Shape matching module, is it possible to access the variables stored in the array with modules other than the VBScript module? For example, could you retrieve a value from the array to use with the IF statement? If so, could someone give a quick example of how to get the min and max shape coordinates out of the array? Thanks.
Jeremy,
You can access individual elements using
[SHAPE_SIZE:2]
where 2 is the third element in the SHAPE_SIZE array.
If you download the latest version you can also use
[maxArray(SHAPE_SIZE)]
which would return the maximum value of the SHAPE_SIZE array. To read more about [] expressions see
http://www.roborealm.com/help/Expressions.php
