roborealm and arduino
mike from India  [1 posts]
I have connected my arduino mega with roborealm and it suppose to control servo but it received information from roborealm but my servo doesn't move at all although it was working fine with simple control code on arduino please help me
Can you post the control code that you tried which worked and the robofile that you currently had loaded into RR? We can then compare the configuration of your working code with what you have configured in the robofile.
I'm also assuming that when running the RR module you had also downloaded the appropriate RR Sketch code that communicates with that module? That will have overwritten your original control code.
