Motors run after I close RR Anonymous |
I am working on object tracking. All i am doing is when the object is detected, the motors for going forward switch on etc. I am using Sparkfun_arduino module to get the PWM!!
The issue is when i quit RR one of the motor starts rotating at full speed (I am using BLDC motors), i am unable to debug that, could you tell me what the issue is. Plz help!!
Thanks in advance!!
When RR disconnects with the Arduino the motors are set to neutral to avoid the problem you are describing. This number is 1500 and set in the g_defaultServo array in the Arduino Sketch. Most likely, this default servo number isn' the right one for your motors. You will need to modify the Arduino Sketch to include a number that does make sense for your motors ... i.e. change that value to what you motors consider neutral.
Note this is a change to the Arduino code and NOT RoboRealm.
