Multiple camera Processing Anonymous |
HI!!
I am using 2 cameras for my robot. The idea is I want to detect the objects from a distance from one camera and do the path planning. And when the robot approaches an object i want to use the other camera for performing tasks on that object. How do i switch between the cameras in the same program? This should happen automatically.
Thanks in advance
You can use the marker module or Camera Properties module to switch the image to another camera. In your case, this would break nicely into 3 tabs. The main tab would just call [active_tab] where active_tab would be initialized to your first tab. The first tab would contain code for the first camera. Once the object is detected you would change active_tab to "tab2" for example which would contain your code for that particular object.
See the attached example.
