refreshing image Roland from South Africa [105 posts] |
7 years
If I use the 'load image' function, it seems that it only loads the image once.
I have this image being updated to file by another program, so I want to refresh the loaded image on cue, but I see no way to do this from a program point of view.
If I put the 'load image' within an if-loop, it simply reads the same buffer.
Is there a way?
Regards
Roland
Steven Gentner from United States [1443 posts] |
7 years
If you download the latest you will see a new "Reload file on change" checkbox just below the filename field. If that is selected, it will check the date/time stamp and reload if that changes.
Note this has a 1 second resolution so if your file changes more than once a second it will only reload the file at most once a second regardless of fps.
7 years
Thanks STeven
Works great.
Regards
Roland
